Counter/Timer
InitialCount on cwcounter
HI,
I have a apps (in delphi with the ocx support for the ni card)  that initialise the cwcounter and work well until that i try to start at a specific number:
   cwcounter1.InitialCount := 445;
   cwcounter1.configure;
   cwcounter1.start;
But when i read the counter:
   CWCounter1.ReadCounter(cnt,overflow);
   edit2.text := inttostr(cnt);
I always have 0 instead of the value that i put.
(4,212 Views)
I miss to let you know that i use delphi 7 and it's a pci-6602 card and i must have componentworks 6.7 or 6.9.
thansk
(4,212 Views)
Hi BoumSenior,
What happens if you set the initial count after you do the configure?  That code would be:
cwcounter1.start;
Does that make a difference?
-Justin M.
(4,189 Views)
Still does the same things, I resolve this with a internal variable in my pgm, and do the calculate internaly instead.
(4,183 Views)
