Counter/Timer
Input impedance of NI 6602 Card
Hi All,
    Why is the Input impedance of the PFI's are Finite? In the data sheet it is mentioned that input impedance is 25k-500k ohms. I have measured the impedance of the PFI channel using a Multimeter and it shows that as 9k ohms. In any case (say even if 25k ohms), why is the input impedance finite?
When i connect my PWM signal to a PFI channel it is pulled down and so pulses ar not detected. I have had to use a pull up to count pulses. So, can any one explain why this input impedance is finite.
Thanks in advance
Message 1 of 1
(5,700 Views)
