Counter/Timer
Internal clock for the counter
Hello everyone,
I am new to NIDAQmx and I am doing angular position measurement. I found provided sample for the counter,
it says that I need to use external sample clock. Could someone provide me sample, that uses external clock that was generated by one task
and another task which uses that generated clock and reads encoder input! I am doing it in C++.
Thank you!!!
(5,927 Views)
Hello Khassan,
Here is a link to a Developer Zone article that describes how to implement two tasks that share a clock, The example covers how to implement this with Analog input and output. You can work with it to fit it to your application: http://zone.ni.com/devzone/cda/epd/p/id/2352
Reagards,
-Travis E
Product Marketer
(5,914 Views)
