Counter/Timer
Is it possible to debug a LV progr. for an NI-6602 in simulation mode?
Is it possible to use the DAQmx Create Channel(CI-Count Edges).vi without actually having the PXI-6602 hardware installed in my PC, i.e. use a simulation driver?
(3,605 Views)
Yes, you can simulate that device through Measurement & Automation Explorer (MAX).
Select NI-DAQmx Simulated Device by right-clicking on NI-DAQmx Devices >> Create new NI-DAQmx Device.  A new window will be displayed and you can select the PXI-6602 through the TIO Series (Counter Timer) category.
All of the data will be meaningless.  Simulated devices are used to help develop software without physically having the hardware.
Respectfully,
Rob F
Test Engineer
Condition Measurements
(3,576 Views)
Hi Rob,
Thanks for the feedback, I was able to use the simulated instrument off-line.
Harry.
(3,570 Views)
