Counter/Timer
Is it possible to generate variable frequency pulse pattern using pci-6624 counter
Hello
I am using PCI-6624 counter\timer card
Is it possible to generate variable frequency finite  pulse pattern using counter , I am using NI PCI-6624 counter/timer card
If it is possible Please tell me how to configure hardware  or how to read the pattern from card i.e. from which pin.
To generate pulse train ,whether I have to connect the  external power supply between vss & Vdd pin Or with out external power supply card will generate pulse train Is it possible to change frequency of pulse train at run time.
Message 1 of 1
(6,496 Views)
