Counter/Timer
Is it possible with cDAQ to output PWM-Signal and Digital lines through same module?
Hello
 I try to output a digital line and a PWM signal through one 9401 module. I use it for actuator control with PWm = speed and digital hig/low = direction.
In LV, I set up cDAQ/_ctr1, then use channel property outport to set it to e.g. cDAQ/module9401/PFI0.
But when I start a second task to use PFI1 as digital output on the same module, the vi fails with timeout error.
Is simultaneous useage possible or will I have to use 2 modules
Thanks for your insights.
Michael
(5,683 Views)
you can upload your LV VI, because I suspect you make a mistake in you're program.
Best regards
Marko
(5,677 Views)
