Counter/Timer
Large frequency counter method reading data at higher rate
Iam using ni 6341 USB device and using Large frequency counter method to measure frequency from 0hz to 10khz which is varying at 200ms but iam not able to get the data perfectly in the chart as well as while  logging the data.The data  comes is of 1 s  instead of 400ms (200 ms for reaching  from 0-10khz and 200ms from 10khz-0).Iam confused as it works for  the ramp (0-500hz at 200ms and 500hz-0hz at 200ms).
I have given sweep (square wave) start frquency 0Hz and stop frequency 10kz with sweep time 200ms and return time 200ms from signal generator and also tested this in the oscilloscope but when i tried  meassuring with ni usb 6341 the problem was occuring .I have connected to counter 0 of 6341
(5,853 Views)
Can you post a VI?
(5,769 Views)
