Counter/Timer
Low profile counter/timer board
Does NI (or anyone else) make a low-profile counter/timer board? Perhaps with specs similar to 6602? If not, are there some other options that I could look into (I think the sample rates may be too high to use USB)?
(5,553 Views)
Accepted by topic author greatgrandpadog
Hi greatgrandpadog,
Unfortunately, NI does not have any counter/timer solutions that are low-profile on PCI.
Our cDAQ-9171 single slot USB chassis has four 32-bit counter/timers that can use an onboard 80 MHz clock (detailed specifications).  For external signals, you would need to use one of our digital i/o module which have various specifications.  You can find a list of them here.  This will be the best way to go for a compact USB counter/timer.  If you have additional i/o, take a look at our CompactDAQ Advisor, where you can use a 4- or 8-slot chassis to expand your i/o in a single system.  For more sophisticated control, CompactRIO offers a similar platform but with FPGA and Real-Time for greater customization and reliability.  There is an online advisor for that as well, here.
Chris Elliott
x36772
(5,546 Views)
