Counter/Timer
Measuring the time signal
Good day! My program reads the signal from the oscilloscope and displays it on the screen. I need to measure the time between two points. Tell me please, how can this be done and are there any similar examples? Thank you in advance! The coordinate of the first point is specified separately. Suppose that -1ma.
(3,444 Views)
What equipment are you using and how are you doing your data acquisition? Is it through LabVIEW or NI MAX?
Marco C.
Applications Engineering
(3,418 Views)
RIGOL DS6064. I use an example for an oscillograph in the labview.
(3,411 Views)
In NI MAX, I see if the oscilloscope is connected
(3,410 Views)
