Counter/Timer
Missing nidaqcns.h
After installing NI-DAQmx 8.7.2 I am missing the file nidaqcns.h which is required for a project I'm working on (using some existing Matlab code to control the counter on a PCI-6024E board). Where can I locate this file?
(4,878 Views)
Hi Peka234,
I think nidaqcns.h comes with traditional-DAQ.
Therefore, you need to enable traditional-DAQ install while installing DAQmx 8.7.2, and make sure that you enable install its sub-option for other text programming languages.
Regards, Kate
(4,818 Views)
Peka234,
You problem depends on what exactly you project is doing but I have attached the file you are missing.  It is likely that you need to look in to the software you have installed as there is probably something missing.  Hopefully this can at least point you to where your problem is.
Sincerely,
Jason Daming
http://www.ni.com/support
(4,801 Views)
