Counter/Timer
NI-6602 VI for simultaneous buffer measures of two channels
Need a VI example for NI6602 counter/timer that will do simultanous buffered mesurements of two channels. The two separate signal sources must be synchronized in time.
(3,412 Views)
Bob,
Below, I have included a link to an example that performs simultaneous, buffered event counting with all eight counters of an NI 6602. You should be able to easily modify this for use with two counters.
Simultaneous Buffered-Event Counting on All Eight Counters of the 6602 or 6608 Devices
Good luck with your application.
Spencer S.
(3,412 Views)
