Counter/Timer
NI 9401 9174 chassis multiple quadrature decoders
Can a single 9401 digital IO board be connected to more than a single counter (for quadrature decoding) in a 9174 chasis using Measurement Studio (not Labview VI) and  ContinuousInputDaqComponent "component" (mxb) model? When I create a second component I get  an Initialization Error (Device cannot be configured for input and output because lines and/or terminals on this device are in use by another task or route.  ... Status Code: -201133
I tried moving the PFIs around with no success. Added Reserve code to Task with no success as well.  This is a 1 Sample (On Demand) MXB generated component model.
If there is an example of multiple decoder code (in C#, C++ or ever VB) somewhere not using the component model
Snippet Below:
            myLinearEncoder = new MotorLinearEncoderComponent();
            myLinearEncoder.TaskReserve();
            myLinearEncoder.TaskCommit();
            myLinearEncoder.DataReady += OnLinearEncoderCounterDataReady;
            myRotaryEncoder = new MotorRotaryEncoderComponent();
            myRotaryEncoder.DataReady += OnRotaryEncoderCounterDataReady;
            myLinearEncoder.StartRead();   <--- fails here
            myRotaryEncoder.StartRead();
(4,945 Views)
Never mind. The reserved task needs to be started last thus the following works:
and in user code for component
        public void TaskReserve()
            Task.Control(TaskAction.Reserve);  //locks GPIO
(4,930 Views)
