Counter/Timer
NI 9401 edges counting forward/backward
How to pragram this application: Pulses will be generated when motor moves, 9401 can count this pulse train when plugging in slot 5 or 6 of 9172. How can i accomplish this: when motor moves clockwise, the pulses count is 1,2.....100; when you chage motor direction, let it move anticlockwise, pulses count will be 100,99.....1. BTW, the motor is brushless DC motor with hall sensor.
(5,371 Views)
Hi terrycong,
You can use an external signal to control whether a counter counts up and down.  The NI-DAQmx Express VI Tutorial shows how to set the count direction to an external source.
If you're using a quadrature encoder, there's some how-to information for configuring those, and the example even uses your exact hardware!
Kyle
(5,300 Views)
thank you for your reply, I have solved the problem successfully.
(5,202 Views)
