Counter/Timer
NI 9411 Specialty Digital Configuration EtherCAT
Is it possible to activate Specialty Digital Configuration for the NI 9411 if placed in an EtherCAT chassis using LabVIEW 2012 RT?
If not, how can I obtain the frequency of the pulses input into a channel of the NI 9411 when it is installed in the EtherCAT chassis?
(6,334 Views)
Hi there, if you are talking about the NI 9144 (EtherCAT Slave Chassis) with the 9411 module...according to this page it is supported. Make sure you have this plug-in and here is a tutorial just in case.
Alejandro C. | National Instruments
(6,315 Views)
