Counter/Timer
NI-DAQ PCI-6602 gate signal:how to select source pin
Hi there,
I am using NI-DAQ 6.9.x for programing the PCI-6602 timer board.
In the 660x Register-Level Programmer Manual on page 3-16 I found that
the the timers should be capable to use the pin dedicated to the source
signal as the gate signal:
"0—Source Pin i; the source pin dedicated to this counter"
This is exactly what I need.
However, it seems to me that in NI-DAQ 6.9.x the command
GPCTR_Change_Parameter (deviceNumber, gpctrNum, ND_GATE, paramValue)
cannot make use of this feature. The paramValue should be set to
something like ND_THIS_SOURCE_PIN but this seems not to exist.
My questions:
1) Is it true that this option does not exist in NI-DAQ?
2) Could it be done in DAQmx?
3) Or do I need to do register level programing in order to achieve it?
Message Edited by Vera on 03-07-2005 08:21 AM
(4,307 Views)
1) I believe in NI-DAQ you'd want to use "ND_SOURCE" as your paramValue
2) It could be done in DAQmx simply by selecting the PFI line as the input terminal
3) I believe this could be done with RLP as well
I hope this helps!
gus....
(4,302 Views)
Using "ND_SOURCE" as the paramValue does indeed work... thanks Gus! dean
(3,934 Views)
