Counter/Timer
NI-DAQ Select_Signal() arguments
iStatus = Select_Signal(iDevice, ulGpctrOutput, ulGpctrOutput,ND_LOW_TO_HIGH);
The above code appears in NI's example program "TIOgenSquareWave.c". I can find nothing in the documentation that refers to this arrangement of parameters. What's going on here? Is this documented somewhere?
Doug Hanna
(3,856 Views)
Doug;
That line is usually used when the counter output is programmed to toggle/pulse when its Terminal Counter is reached.
The will force the output of the counter to perform the specified action and actually output a signal.
Hope this helps.
Filipe
(3,856 Views)
