Counter/Timer
NI-DAQmx: M Series Pulse Width Modulation (PWM) not working with USB-6211
You should probably start a new thread assuming you aren't running into the same problem as the original poster.
Also... in your new thread it would be good for you to describe the issue you are seeing and describe the troubleshooting steps you have taken so far.  I actually haven't looked at your VI (no LV 2012 on this computer), but you haven't described the issue that you're asking for help with at all (or even described what it is you are hoping to accomplish) so I can only give very general advice.
Best Regards,
John Passiak
Message 11 of 11
(989 Views)
