Counter/Timer
NI PCI 6221 and SCB-68 and timer
I'm using NI PCI 6221 and SCB-68.  Can I use timer with Single Two-Signal Edge-Separation Measurement. Is this type of measurement can be set with that hardware combination. I,m asking becouse when I,m using DAQ ASSISTANCE it pointing the pin name that doesn,t exist on the SCB-68.
(4,429 Views)
Hi Fazi,
The SCB-68 has pinout labels for E-series DAQ cards while the NI PCI-6221 is one of the newer M-series DAQ cards.  The Single Two-Signal Edge-Separation Measurement you want to take is possible with your card.  Below is a KnowledgeBase article which gives the SCB-68 pinouts for M-series cards. Let me know if this fully answers your question or I assumed something wrong.
SCB-68 Quick Reference Label for M Series
Alex A.
(4,405 Views)
That explain me everything I wanted to know. Thank you
(4,395 Views)
