Counter/Timer
NI PXI-7811R PXI trigger line
Dear reader,
i have a simple question, is it possible to use the pxi trigger line with a NI PXI-7811R. I fount out that it ist possible with NI PXI-7831 R!!
When it is possible, is it also possible to use the star trigger line (I think not but I want to be sure)
...thanks a lot...
(4,319 Views)
Hello Sebastian,
Yes the NI PXI-7811R can use the PXI star trigger line to send or receive triggers from a device plugged into
slot 2 of the PXI chassis. The PXI star trigger line on the NI PXI-7811R is PXI/STAR."
You can use the Digital Input or Digital Output FPGA functions to read and write from the STAR trigger.
Page 2-5 of the PXI-7811R User's Manual has a section on the PXI Trigger Bus that goes into a lot more detail.
Kind regards,
Elmar
(4,309 Views)
