Counter/Timer
NI9011 and NI9411 lost points from quadrature encoder
Hi! Were you founded 30mm/min? In attached image that I post, you can see at 100khz=12M/min. And more, the mechanic permissive speed is 30M/min.
Thanks for your help!
Rúben Jerónimo
Software Developer
Streak, Automation Engineering
Message 11 of 17
(3,398 Views)
my mistake. you are correct.
so, what speed do you see incorrect readings?
Stu
Message 12 of 17
(3,392 Views)
how are you determining that you are missing edges?
Stu
Message 13 of 17
(3,389 Views)
Hi! I see incorrect measures at max speed. I cannot precise the specific speed, but is when I move the encoder really fast.
I know that I missing points because the encoder losses the reference point.
If u want tomorrow I can do a video to show you the problem.
Thanks for ur help!
Rúben Jerónimo
Software Developer
Message 14 of 17
(3,384 Views)
how fast do you estimate you are moving the encoder when you see issues?
at 24m/min, that is 400 mm/sec.
since i have used this module at greater rates than you are trying to, i am still wondering if it is the encoder electronics instead of the module.
Stu
Message 15 of 17
(3,367 Views)
Hi Stu, thanks for your reply!
I estimate that i'm moving the encoder near max mech permissive speed (30M/min). Are you saying that maybe can be a encoder electronics problem/limitation? I have already tried with another encoder exacly like this and the results are same. Thanks for your help!
Rúben Jerónimo
Software Developer
Message 16 of 17
(3,358 Views)
Hi everyone! I still without success. Anyone from NI can help me?
Rúben Jerónimo
Software Developer
Message 17 of 17
(3,319 Views)
