Counter/Timer
PCI-6229 Counter not working...
I am trying to measure a low frequency pulse width of a square wave with amplitude of 4 V.
Using the sample code "Meas Pluse Width -Buffered-Cont.vi"  supplied with LabVIEW . The card I am using is PCI-6229. The source is a function generator and the output of the same is connected to PFI-8 terminal ( Ctr-0 Src)and Ground to DGND of the card. I am able to read the frequency of 10 Hz right at these terminals using a scope but the VI reads zero. And no error is also reported.
What could be wrong ??
Raghunathan
LabVIEW to Automate Hydraulic Test rigs.
(6,641 Views)
Hi Raghunathan,
Pulse Width Measurements actually require to use the Gate of the counter (PFI 9 by default).
Best Regards,
John Passiak
(6,632 Views)
Hi John!
Do you have the correlations betwen PFI and their  Functions? For example, I'd like to know the PFIs  for the counters.
thanks
brás
(6,442 Views)
Hi brás,
The default PFI lines for the various counter inputs on your particular device can be found by checking the device pinouts in MAX.  On most devices, you can change which PFI lines to use through DAQmx Properties.
For finding out which counter terminal is used for various measurements (e.g. source vs. gate), refer to the Counters section in the User Manual for your product (e.g. X Series User Manual).
Best Regards,
John Passiak
(6,428 Views)
