Counter/Timer
PCI 6251 ConfigureAnalogEdgeTrigger
Hello, I try to start a measurement on a analog signal. This signal is a positive pulse. When it arrives, i start to count until the signal on "ctr0" arrives. So i try to configure a analogTrigger on APFI0. But the following error occurs : "Specified property is not supported by the device or is not applicable to the task Property : CNiDAQmxStartTrigger::type Task Name : BancDeTest Status Code : -200452 Any one can help me ? Thank you. I've attached two files
Message 1 of 1
(3,380 Views)
