Counter/Timer
PCI-6601
I'm trying to figure out if PCI-6601 counter/timer board is compatible with Windows 11 and the current LabVIEW 2025. That board has been installed and running on a Windows 7 computer so I wasn't sure if it can still function if transfer to a newer computer.
Thank you!
(3,016 Views)
According to NI Hardware and Software Operating System Compatibility, PCI-6601 is supported in Windows 11 with NI-DAQmx 2022 Q3 or later. You can use the latest LabVIEW 2025 and NI-DAQmx 2025
https://tmesystems.net/
(2,997 Views)
Awesome! Thanks!
(2,918 Views)
@coffeeLord1306 wrote:
Awesome! Thanks!
I am curious to know which PC (make, model) supports PCI slot and TPM for Windows 11.
Santhosh
Soliton Technologies
(2,905 Views)
