Counter/Timer
PCI-6602, Semi Period Finite Buffered Position Benchmar
Hi All,
I'm using a PCI-6602 to acquire semi period measurement in a buffered and finite way. I'm expected to acquire a signal with a rate at 3 MHz for a lenght of 5M measurements.
I'm using Lv 2010 + Daqmx 9.4, and I'm façing a DMA overwritten issue when I apply a square signal over than 2 MHz.
The following link details some bench (done by NI) for same kind of measurements and results are better than mine:
http://digital.ni.com/public.nsf/allkb/A696607CD6864B568625692E004A9316
This document gives a 3.35 MHz perf for a finite semi period measurement. I think that this benchs were done with DAQ Trad, but I was expecting to obtain close results.
I'm using the basic example shipped with Lv (as detailed below), on a new and fast computer:
https://forums.ni.com/t5/NI-DAQmx-Examples/Measure-Buffered-Semi-Period-Finite/td-p/3502946
Is there any up to date Daqmx made benchmark? If yes, is it possible to get an example to achieve a higher performance?
Thanks for your help.
Cordialement,
Raphael T
Message 1 of 1
(5,809 Views)
