Counter/Timer
PCI-6624 Calibration
I need to calibrate a PCI-6624. Does a cal procedure exist for this?
(4,006 Views)
Hi DTI1,
Unfortunately, this device is not supported in Calibration Executive. The supported hardware can be found from:
You can consider other calibration options:
Calibration Solutions from National Instruments
(3,998 Views)
What would you like to calibrate on this device? The input thresholds are roughly the same as TTL, so they cannot be adjusted and you must provide the reference voltage for the outputs, so you would have to calibrate that device yourself. As far as the timebase source goes, you cannot calibrate it, but you could measure its accuracy and make adjustments yourself. There are verification instructions for the 6601/02 here which could serve as a starting point, but you'll have to use RTSI lines instead of the PFI lines for measurements to bypass the optocouplers.
I hope this helps!
gus....
(3,994 Views)
