Counter/Timer
PCI-6624 user manual
I need the user manual of the PCI-6624. I can not find it on the web site.
I need informations about which signal i can route on the gate and on the source of counter.
Tanks.
Message 1 of 10
(5,610 Views)
You can find this information in Measurement and Automation Explorer (MAX) by selecting your device and looking at the "Device Routes" tab. This tool in MAX will show you all the possible routes and destinations on the 6624.
I hope this helps!
gus....
Message 2 of 10
(5,603 Views)
I don't have the PCI-6624 board (I plan to buy it).
I found the following information on the TIO help file :
"You can select any PFI or RTSI, as well as many other internal signals like the Counter n Gate (CtrnGate) signal. ".
So, i think that i can connect the PFI14 (default CTR 6 GATE) to the CTR 1 GATE ?
Is it true ?
Thanks.
Ben.
Message 3 of 10
(5,597 Views)
Ahh. I get you now. Yes, you can connect any of the PFI or RTSI lines to any counter gate. Post again if you have any other questions about the 6624.
gus....
Message 4 of 10
(5,591 Views)
Thanks for your help.
Now, I known that i can use a PCI-6624 for my application.
(why there is no 'pdf' used manual for the PCI-6624 ? It is a mystery ....)
Ben.
Message 5 of 10
(5,587 Views)
You can find user manual of NI-6624.
The user manual is the same for TIO devices. You can find your answer at "Counter n Gate signal" page.
Isabelle
Ingénieur d'applications
National Instruments France
Message 6 of 10
(5,582 Views)
I prefer pdf file to help fiel like 'TIO_Series_Help.chm'. But it is ok.
I need another confirmation : is true that it is not possible to read the state of the PFI input line and write the state of the output PFI line of the PCI-6624 ?
Message 7 of 10
(5,570 Views)
The NI 6624 has 34 PFI lines, with 26 inputs and eight outputs. The PFI lines are unidirectional. They are set either as inputs or outputs. An input cannot be configured as an output and an output cannot be configured as an input through software.
Isabelle
Message 8 of 10
(5,565 Views)
I know that it is not possible to configure an input as output and vice versa.
I want to know if it is possible to read the input like an input of a digital i/o board. For example, is it possible to read PFI39 or PFI38 with NI-DAQmx ?
Where is it written in the documentation ?
Ben.
Message 9 of 10
(5,562 Views)
The NI-6624 doesnt provide DIO context. I think that you cannt read or write PFI line as digital line. But you can do it with NI-660x devices.
Isabelle
Message 10 of 10
(5,521 Views)
