Counter/Timer
PCI6602 to detect TTL output from single photon counter
Dear all,
I am learning how to use Labview.
Here is the system I try to set up.
1.   Single photon counting module, 2.5v TTL output, 20MHz light source
2. BNC-2121 block
3. PCI6602
4. Labview 7.0, NI-DAQmx
The aim of this system is to counts the number of the detected photons from the light source.
I have problem to start this task. Can you guys help to creat a sample which i can start from?
Your help will be greatly appreciated.
FrankieSmiley Indifferent
(3,826 Views)
Hi Frankie,
I would suggest using the NI-DAQmx counter shipping examples to get started.  The Count Digital Events VI would be a good starting point.
You can open it through:
 Help >>
Find Examples >>
Hardware Input and Output >>
DAQmx >>
Counter Measurements >>
Count Digital Events >>
Count Digital Events.
Hope this helps!
Micaela N
(3,813 Views)
hi, michael
Many thanks for your help.
Frankie
(3,805 Views)
