Counter/Timer
PNP input to PCIe 6612
What is the easiest way to connect a PNP (current sinking) encoder to a counter-timer?  I need to trigger some electronics using a PNP encoder, and it appears the 6612 counter-timer only accepts NPN (line driver) inputs.  Is there an easy way to do this?  I see several references that some NI cards can be configured for both PNP and NPN, but there is very little information on which ones and on the 6612.
(5,394 Views)
(5,386 Views)
