Counter/Timer
PXI-6602 Register Level Initialization
I am trying to program a PXI-6602 using Registry Level Programming.
It is hooked up to a BNC-2121 so I can check activity.
I would like to know how to
   1. Configure the DIO_! through DIO7 as Outputs. The manual says to write registers BAR1 Offset 0x77C and 0x780 with 0x02020202.
       This seems to work.
    2.
(4,128 Views)
       This seems to work.
    OOps - I got shipped out
   2.  When I try to Write to the published IO Registers the unit doesn't write to the outputs.
        This board works fine using MAX, so I know it is pilot error.
(4,119 Views)
Austin,
Register level programming is supported solely within the DDK discussion forum.  Please start this thread there and it will be much more likely to be answered in a timely manner.  Thanks!
DDK Forum Link: http://forums.ni.com/ni/board?board.id=90
Lon
(4,098 Views)
moved...
(4,085 Views)
