Counter/Timer
PXI-6653 DDS ClkIn reference
When I use the example with NI-SYNC called Generate DDS Clock and Route.vi and select DDS Clock Source Terminal: ClkIn, and Destination Terminal: ClkOut, the card does not generate an output clock. If I then click stop, I'm given the error message:
Error -1074118606 occured at niSync Connect Clock Terminals.vi
Driver Status: (Hex 0xBFFA4032) The specified source terminal is invalid for this operation.
If I change the DDS Clock Source Terminal to one of the other sources, I get a signal on ClkOut, but it is not phase locked to my external 10MHz reference oscillator.
How do I generate a DDS clock signal which is phase locked to an external 10MHz reference oscillator connected to ClkIn?
John Bosshard
(5,363 Views)
Hi John,
You need to use two LabVIEW examples for this task. Run the Check Clk10 & Route Clock.vi first to route ClkIn to the backplane PXI_Clk10. Then run the Generate DDS Clock and Route.vi to route the PXI_Clk10 to ClkOut. This will work as long as your signal meets the backplane 10MHz clock specifications.
Thank you,
Simran K
(5,347 Views)
Even when run by itself, "Check Clk10 & Route Clock.vi" fails. Upon running it, I get "Error -1074118606 occured at niSync Connect Clock Terminals.vi"
Possible reason(s):
"Driver Status:  (Hex 0xBFFA4032) The specified source terminal is invalid for this operation."
So--essentially the same error as above.
(5,344 Views)
Accepted by topic author jboss
Solved--PXI-1033 S1 backplane jumper needed to be moved.
John Bosshard
(5,336 Views)
Hi John,
Thank you for letting me know and I am glad everything is working now.
Simran K
(5,328 Views)
