Counter/Timer
Parallel execution gpib communication, measurement?
I am a french student in internship.
I use the counter 53132A Agilent. Labview receives informations from GPIB bus.
I make continuous measurements on the channel 1, so i can't use "READ" or "MEASURE" requests. It means that, when a gate is over, an other one starts immediately.
I think "FETCH" command is the only command available for my application.
My questions are :
- When I send a "FETCH" command (last measured frequency) from my computer to my counter, does it stop the current measurement to answer?
For my part, i beleive the frequency is read on a buffer inside the counter and sent on the GPIB. In the same time, the counter still measures on the specified gate.
- How could I evaluate the max speed of my application? (if my hypothesis is true, the max speed is the maximum of {the lowest gate time of the counter (1ms) and the time of a GPIB answer}).
Thank you in advance for the answers.
(4,020 Views)
Hello.
Do you still have your problems?
I think the same for the measures of the current but I'm not sure. You don't have the answer in the technical manual of your counter?
Regards.
Romain D.
National Instruments France
(3,966 Views)
I read the programming guide and the operator guide of my counter (53132A Agilent) but nothing...
I called Agilent France but i'm still waiting for their answer.
I'll post when I get news.
(3,958 Views)
