Counter/Timer
Problems in Synchronisation between AI and Counter
I am using NI USB-6353 to measure an analog input signal and counter periods. The two created tasks must start synchronously.
I used this VI as a template and only changed the Encoder Configuration from CI Angular Encoder to CI Period. The problem is, that I always receive error -201314 (Multiple Sample Clock pulses werde deteceted within one period of the input signal). Isn't it possible to synchronize CI Period and an analog input?
(4,340 Views)
Hi ugccz,
you see this error, because the Samplerate you use is too fast. There is a KB for this topic, I recommend to read this:
http://digital.ni.com/public.nsf/allkb/18E8B27384BBCC7B86257A6800618056
So if you use e.g. 1kHz Sample clock, but the period you want to measure is longer than 1ms, you are trying to read a sample, when the period-measurement hasnt finished. Thats why you get the error. An Alternative is to use implicit timing, wich gives you a sample whenever the measurement is finished. But this wouldn't be synchronized with the AI task.
I see two solutions here:
1. Use implicit timing, and read 1 Sample as a Waveform. This will give you a timestamp, and you can later synchronize the acquired AI-Array with the Samples received (wich are not equally sampled). But since the Timestamp received from DAQmx is not super-precise, this might not be suitable.
2. I hope this works, but just give it a try. Use Sampling Type "1 Sample Hardware-Timed". Lets say you have 1kHz Samplerate, and 1.9ms Period-length. Then around every second time you try to read a sample you will get the error (The error occurs at DAQmx-REad.vi, right?).
Whenever the error occurs, you just ignore it, and output the last valid sample. I attached some example code as a screenshot (its a VI-Snippet, just drag&drop it to the blog-diagram to add the code there)
3. You can also consider using a slower sample-rate, if this is still within the specs of your application.
Just try the approach thats most suitable for you, and give me a short answer if it works now. Thanks!
Best,
Jan Göbel
Staff Applications Engineer
(4,291 Views)
Its 3 solutions ...
(4,290 Views)
Thank you for your answer.
The specs of my application need a fast sample (2 MHz). I solved my problems now by using CI angular encoder. In this case, I can synchronize AI and CI without any errors.
(4,264 Views)
