Counter/Timer
Programming the NI-DAQmx C API with Bloodshed Dev-C++, linking library?
Hi!
I'm trying to program the NI-DAQmx C API in Bloodshed Dev-C++ in order to control a PCI 6602 card. The library / include directories are set, nidaqmx.h is included, nidaqmx.lib mentioned to the linker. I'm getting linker errors ([Linker error] undefined reference to `DAQmxCreateCOPulseChanFreq@44' etc) for each function call.
Is there a linker definition file .a or has anyone an idea where my error may be?
Thanks a lot!
CU
CJ
PS: I hope this board is the right one.
(3,691 Views)
.oO ( Don't know why it always has to be that way round ...)
Just found this forum thread and got reaction by using the supplied .a file on page 2.
I think if you'd be able to supply such a file directly it'd spare many some work.
CU
CJ
edit: Bad english corrected.
Message Edited by c.jesch on 06-20-2005 04:58 PM
(3,689 Views)
