Counter/Timer
Pulse generator test panel error -88302 with PXI-6608
I get an error (-88302) showing an unspecified "internal error" when running a Pulse Train Generation test panel in MAX with a PXI-6608 counter/timer.  The controller is PXI-8108RT and MAX is the latest version 5.1.0f0 and LabVIEW 2011 / RT are also latest revs.  This is odd, because I have no problem running pulse generator vi's with this card.  The card passes self-test in MAX and the digital output test panel seems to work OK.
Does anyone know if there's a bug in the latest rev of MAX or DAQmx?  I don't recall this problem occurring before.
(6,088 Views)
Hi byronb,
I would suggest you reinstall the DAQmx drivers, you can try to download the version 9.5.1 that can be found here.
steve.bm
AE | NI
(6,079 Views)
Yes.  I'd thought about a complete driver reinstall.  The system isn't available at the moment, but I'll try that when we get it back on line.  An odd problem.
(6,073 Views)
