Counter/Timer
Quadrature Encoders and NI-MAX
I am using the NI 6259 DAQ to read a quadrature encoder.  The datasheet for the 6259 states that any PFI designated channel can be used as a counter/timer; however, there are only two channels that seem to work.  When I set up one of the other PFI channels, the encoder read out on NI MAX changes from 0 to 36m, but nothing in between.  It appears to be set up exactly the same as with the two channels that work.  Any suggestions on what I could be missing?  Are not all PFI channels created equal?
(3,908 Views)
Hello jsholl :
As fas as I understand your issue is related to the number of clocks on the NI-6259. See the page 13 from the attached link:
DEVICE SPECIFICATIONS NI 6259
http://www.ni.com/pdf/manuals/375216c.pdf
(3,878 Views)
I understand that the number of counters is limited to 2 on the 6259.  In the documentation, it states that any PFI channel can be used as input for the counter.  When I attempt to change which PFI channel is used for the encoder set-up, it still seems to act like a digital input instead of a counter.  Is there something special I have to do to designate the channel as a counter?
(3,873 Views)
It appears I need to change the default NI-DAQmx counter terminals.  Right now CTR 0 A is set as PFI 8 (Pin 37) and CTR 0 B is PFI 10 (Pin 45).  I want CTR 0 A to be PFI 14 (Pin 1) and CTR 0 B to be PFI 12 (Pin 2).  How can I change the default set-up?
(3,867 Views)
This post shows how I did it in labview:
https://forums.ni.com/t5/Multifunction-DAQ/quadrature-encoder-based-triggering/m-p/3128787#M85838
I don't know if you can change the PFI terminals in MAX, at least for me they're hard coded to defaults.  It's easy to do in labview/c/.net though using the A/B/Z inputterm settings.
(3,859 Views)
Accepted by topic author jsholl
We were able to fix the problem in our VI.  A staff member remembered it was referenced in the VI.  Once we changed the channel referenced to the desired one, we were able to read the encoder.
(3,832 Views)
