Counter/Timer
RTSI at 80MHz
Hi
I'm using a NI5640R board. Is it possible to set the RTSI clock at 80 Mhz in the Host vi changing in some way the Configuration timebase vi?
With this vi I can set the RTSI clock at 200 100 50 25 12.5 MHz but 100 is to high for the FPGA vi (the maximun when compiled is 95 MHz)  and 50 is too low for what I need to do. I tried to pipeline the FPGA but there were no significant results.
Thanks in advance for your help.
Emanuele
Message 1 of 1
(3,435 Views)
