Counter/Timer
Ramping a pulse signal using PCI-6602 card
Before this thread gets too old and dusty, I'm gonna post the example I worked up.  The descriptions I give are from memory b/c I don't have a LV pc nearby and it's been a week or so since I last opened it.  If there's any response here, I'll follow up with more description and comments.
Keypoints:
1. Generates a finite pulsetrain with an exact # of steps by using features built into the counter hw.  The minimum # of steps is 2.  The counter configuration is pretty much as described earlier in this thread.
2. Allows the pulsetrain to have its frequency varied on-the-fly.  This is useful for ramping a stepper.
3. The frequency update operates in a timed loop that uses the pulsetrain as its timing source.  This guarantees that we don't get the error from changing a freq setting 2 times before the first setting produces a full pulse cycle.
4. Another counter from the 660x is used to count edges of the finite pulsetrain and give hw verification of the # of pulses generated.  (If you remove the code involving this counter, I think you should be able to use the example with an E-series or M-series board too).
5. The ramping algorithm is pretty crude, but the intent is to produce a ramp where the frequency changes linearly with time (not with step #).  On each iteration of the timed loop, I calculate the appropriate delta freq based on the current frequency and the time since the last freq update.  In a real app, this algorithm would need further work including a means for ramping down.
Happy counting!
-Kevin P.
Message 21 of 21
(1,546 Views)
