Counter/Timer
Re-Triggered delayed Pulse in DOT.NET
I am trying to set up a counter for a simple re-triggered delay pulse.
This is easy to do in the old DAQ lib but there does not seem to be a way to do it in DAQMX with DOT.NET. (C#)
I think the old one was ND_SINGLE_TRIG_PULSE_GRN.
I can not find out how to do it in DAQMX or for that matter most of the other counter timer functions available in the old DAQ lib.
The DAQMX help is pretty useless skipping all over the place.
Perhaps NI should re-look at there old NI DAQ function reference book and remind them selves how to write useful manuals.
There are no sample code for this or for the manny other counter timer function that are available in the old DAQ.
Hence I think MX is far from comlete.
Is thev old problem of not being able to change the delay or the pulse with on the fly for a triggered pulse fixed.
Seems that DAQMX is still in beta as most of the counter timers function are missing.
I also need to rewrite a function that measures the time between two pulses (Start trigger and stop trigger).
The DAQ Wizard seems to be very limited.
My work output has slowed right down with MX.
Colin
Message 1 of 1
(3,335 Views)
