Counter/Timer
Routing onboard clock to PFI line with DQAQmx
I am using 6602 board and DAQmx "Count Digital Events-Buffered-Continuous-Ext Clk.vi. Is at any way to use onboard clock (80 MHz) as a source for the edge counter. If I add source in DAQ channel property I am getting error: "not supported property"
(3,600 Views)
Here's a screenshot of what worked for me. All I added to the shipping example was the DAQmx Channel property node. Did you do it this way and still have trouble?
-Kevin P.
(3,600 Views)
Thanks a lot. That works.
Aleks
(3,600 Views)
