Counter/Timer
Sample Encoder with BNC2120 & PCI 6122
I have an angle encoder and I am trying to sample the output TTL signal (0-5V). I want to count the steps, considering that after every step (0.1 deg) the signal switches from high to low or viceversa.
The encoder cabling is correct.
1) Where should I put the wire on the BNC 2120? On the counter pin CTR? If yes, I have different CTR counter pins: gate, source, output (if I am not wrong). On which one I have to connect it?
2) How should I set the DAQ-MX express VI for acquiring the signal?
Thank you very much for your answers, consider that I am not very expert with electronic and programming.
(4,208 Views)
you have to connect the ttl signal to the source of CTR  (PFI8).
Take a look to the example at the link
http://zone.ni.com/devzone/cda/epd/p/id/2641.
Hope this helps.
Clara
(4,199 Views)
