Counter/Timer
Sample clock vs sample per channel per second
Referring to this link http://digital.ni.com/public.nsf/3efedde4322fef19862567740067f3cc/dbe7ac32661bcf9b86256ac000682154?OpenDocument
What's the difference between sample clock and sample per channel per second? Looks the same to me.
(4,685 Views)
The sample clock is the clock that sets the timebase for channel operations on the board.  The samples per channel per second is the actual rate at which data can be transferred on a particular channel.
Alex A.
(4,666 Views)
Hi Alex. So if i want to control the sample rate of my daq that would be 'samples per channel per second' correct'
(4,656 Views)
Yes, that is the value which is your data acquisition rate.
Alex A.
(4,650 Views)
