Counter/Timer
Save time in a table
Hi people!
I have a doubt and I think someone from here have the soluction.
In the picture I add you can see a "result" , this is the time 00:00:00.000 and when the max value is less than 4,5 start time if not reset the time.  I want to save this time in a table but...I'm bit confused...
I have to use a shift register or what..?
Any idea?
thanks,
(5,747 Views)
I tried something like this..
(5,745 Views)
Hi jocuma,
You must be comaring the time with 4.5 right? which will give boolean true/false. Connect this to simple case strucure. In true case, save the timing.
uday
(5,688 Views)
