Counter/Timer
Simultaneous input and output on a cDAQ & NI 9401
I'm relatively new to Labview and this is my first time dealing with DIO so please bear with me. I need to produce a PWM signal on one channel to control some motor drives and measure the frequency of pulses on 3 channels to determine RPM of the motors. I've gotten the PWM working but I'm having trouble with the inputs. I've set up a separate task for each input put when I run them in MAX with no signal input I get this error. (see below). Also the input signal will be at zero when the motors stop but It appears you can't have less than 1 for a minimum in the input range. How can I deal with that?
(4,261 Views)
I believe the following article will help you configure your device properly.
Configuring the NI 9401 for Input/Output
http://digital.ni.com/public.nsf/allkb/4828F9A252F081758625731E007D85F9
(4,231 Views)
Thanks LLaura,
Unfortunately that article deals mostly with compact RIO. They do reference using counters with a cDAQ chassis but pretty much just says you can do it.
(4,221 Views)
Althought this thread has been not active now for a long time, I found what Llaura said but explained a bit more in depth:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P6TtSAK
It worked for me. My configuration is a cDAQ-9174 + NI-9401.
Javier
(3,421 Views)
