Counter/Timer
Sync Multiple Counters
I want to start 3 counters on a 6624 board simultaniously. The counters should count edges from 3 diffrent sources. I am using Labview 8.0.1
Can I start those 3 counters with a software generated signal (I have no external HW Trigger)?
I was thinking about something like you start an AI and AO operation simultaniously. But it seems that there is no corresponding trigger event (ai/StartTrigger) for counters available.
Thank you for your help in advance,
Peter
(3,982 Views)
you have no software trigger like ai/StartTrigger which you can use. Attached you can find an example where 3 counters will be started from a 4. counter. The 4. counter generate a puls. The 3 counter are configured with a pause trigger.
If you use this example be careful, the 6624 has inverted logic (see manual,
TIO Series -> Device-Specific Information -> NI 6624 -> Input).
For the 4. counter you need separate Source voltage (see manual) to generate the puls.
hope this helps
Michael
(3,966 Views)
Thanx Mike,
worked great
Peter
(3,942 Views)
