Counter/Timer
Synchronizing 4 Counters to Countdown Backwards 1 at a Time
I'm new to using multisim and was trying to get four timers to countdown 1 at a time from 9 to 0. Counter 1 9 to 0 then shuts off then the counter 2 does the same then to counter 3 then 4.
(4,163 Views)
Hello, I am sorry. But what is the specific question?
(4,130 Views)
If I were to build a circuit using multisim that has four counters, how would I get them to countdown one at a time.  The first counter would countdown from 9 to 0 then shut off then the remaining three would follow the same pattern.
(4,128 Views)
Have you already check this up?
(4,103 Views)
Thank you GrouchyMama. I looked for "async_counter.ms12" file but couldn't find it. I will try and build this to see how it works.
(4,080 Views)
