Counter/Timer
The best way of eliminating any false pules while aquiring on counters in Daq card
usually i monitor the RPM of any moving object and for that i use inductive proximity sensors for the same. These proximity sensors are supposed to give out a pulse at every rotation. for monitoring and all i count the no. of pulses at eihter of the counters in my DAQ card. most often what happens is i use to have false pulses in between also and that results erratic readings. So i wanna know if this problem is solved by software filtering and all or there is some hardware solution. how can i be sure that the conter is always counting the right no. of pulses.
Please have a look into the problem and give ur valuable solutions.
Regards
GNS
(3,291 Views)
It is not possible to due filtering in software when using counters. You would need to write an algorithm that would decide whether a pulse was valid. This is simply not possible. What you need is either a low-pass filter circuit to remove any false edges or you need one of our counter/timer boards that have built-in filter clocks that can also reject false pulses. Here is a link to our 6602 board which would work very well for your application:
http://sine.ni.com/apps/we/nioc.vp?cid=1123〈=US
If you choose to implement a simple RC filter, you will simply need to choose R and C combinations that will reject the high frequencies, yet not attenuate your actual signal.
Bill B
(3,291 Views)
