Counter/Timer
Time domain plots-problem with setting the time counter
I need to control a signal generator and a vector network analyzer using labview. I am sending a signal from signal generator and measure transmission from VNA. I want to plot voltage vs time at the input and at the output. My problem is how to set the time counter at the input and output.
I really appreciate you help. Thank you in advance.
(5,820 Views)
This is the VI I am using to measure input and output voltages. I am having problems how to insert time counter at the input and output.
Thank you
(5,810 Views)
If you're looking for time information coupled with your voltage reading, it's best if you build a waveform. To do so you can use this function.
You will need to get the time at which the voltage reading starts (by getting a time stamp) and connect it to t0, and define what the time step dt will be.
I hope this answers your question.
Tarek B
(5,800 Views)
