10-02-2007 06:33 PM
10-03-2007 09:02 AM
In LabVIEW, there are DAQmx property nodes that will let you set or query the timebase. Probably available in a Channel nodes if you dig down a ways in the menus.
I've gotta ask though, ahat do you intend to do with this timebase once you learn how to select it? Because the notion of a timebase doesn't really make sense to me for an edge-counting task. You're simply incrementing a count as edges come in. The timebase doesn't get involved.
-Kevin P.
10-03-2007 11:36 AM
Hi we are using Labwindows. The purpose to know the timebase is to ensure that it's a higher frequency than
that of the signal whose are being counted. In our case the signal frequency is 10Mhz. We are using the M series 6251
DAQ card. So if the timebase of the counter is 20Mhz or 80Mhz we should be ok.
-Charles
10-03-2007 12:33 PM
It sounds like you're thinking "Nyquist", which doesn't really apply to TTL edge-counting operations. The board isn't trying to digitally sample the incoming 10 MHz signal. It simply has circuitry that increments a count register on every incoming TTL edge.
The speed spec that matters is named something like "maximum external source frequency". Hmmm, I couldn't find any such spec in the M-series detailed specs or online manual. Best guess is that it's around 80 MHz to match the max available internal freq. I surmise this based on the datasheet for the similarly functioning counters of the 6602.
-Kevin P.
10-03-2007
01:11 PM
- last edited on
08-06-2025
11:15 AM
by
Content Cleaner
Hi Charles,
The PCI-6251’s specifications manual is a great resource. On page 9 it indicates that the internal base clocks are 80MHz, 20MHz, and 100kHz. The last two are just divide-downs of the master 80MHz clock. Post again if you have further questions.
10-03-2007 01:22 PM
I'm just hoping if you could confirm that the default timebase for the counter of a 6251 device
is 80Mhz. The documentation is ambiguous in this regard.
-Charles
10-04-2007 01:51 PM
Yes, the maximum timebase is 80MHz for an M-series card. It is selected automatically based on some different parameters such as the input frequency. You can read what value it is currently set to with a property node. A list of the property nodes available are found in the NILabWindows/CVI Help (Start -> All Programs -> National Instruments -> LabWindows CVI X.X -> LabWindows CVI Help) under “list of timing properties”. Look under Sample Clock -> Timebase.
There are also a few different counter methods. A good resource for learning about what they are and when to use them is the NI-DAQmx Help (Start -> All Programs -> National Instruments -> NI-DAQ -> NI-DAQmx Help). Look under NI-DAQmx Key Concepts -> Counters.
If you have other questions, let me know.
