Counter/Timer
Triggering two conuters with two digital signals
i am doing some period measurements using a 6221 M-Series card with two counters.
My problem is now to trigger them with two different digital TTL signals. How can i do this?
(Period times Signal 1 <-> Trigger 1, Period times Signal 2 <-> Trigger 2)
Has someone an example vi?
regards
Jens
(3,450 Views)
Here you can find an example, that shows how to use a trigger for a counter. It is not exactly what you want, but shows the rigth way. Hope it helps:
http://zone.ni.com/devzone/cda/epd/p/id/1612
(3,440 Views)
Thank you very much! It helped me very much!
(3,435 Views)
