Counter/Timer
Try to start 2->error: Counter No DMA channel aviable (PCI 6601)
If i try to start to counters ( Encoder measurement), the first Counter start correct, but if i try to start the second counter i get a error "no DMA channel aviable".
I use Visual Studio 6. Do have somebody a sample programm to show me the correct handling with this DMA channels?
Thanks for helping
(3,496 Views)
This error usually arises when you are trying to use more DMA channels than available on your computer: are you performing other tasks on the acquisition card (i.e. analog input / output) while you are acquiring the counters?
The general solution to it is to transfer some of the acquisition/generation tasks to interrupts in order to leave DMA channels free for other tasks. Use this instruction to do this:
Set_DAQ_Device_Info (1, ND_DATA_XFER_MODE_GPCTR0, ND_INTERRUPTS);
customizing it to your needs.
Since DMA is faster and more adapt to high data volume transfer, usually I set acquisition and generation to use DMA and set counters to interrupts, but your application can require a different setup.
Hope this helps
Roberto
(3,496 Views)
